Gtir Motorsport club » Tech room » Help and Advice » Random squeel from rear
1Random squeel from rear  Empty Random squeel from rear on 20th June 2015, 10:58 am
Keensie
I,ve had this random noise for some time now infact several years and never managed to find out the cause,it sounds like a high pitched squeel only at low speed 10mph from the rear, the calipers have been rebuilt all is good there so could it be wheel bearing?all is perfect at any other speed it's just so random never got worse but if it was wheel bearing noise shouldn't it of failed years ago?.It seems to be coming from the N/S so would a cv joint make this noise or the diff i,m really stumped any ideas that could guide me would be most appreciated.
2Random squeel from rear  Empty Re: Random squeel from rear on 21st June 2015, 2:35 am
More info, when braking when turning when on gas or off gas, bumps etc ...
3Random squeel from rear  Empty Re: Random squeel from rear on 21st June 2015, 7:11 am
Dust shied on rear brakes fuel pump wine but you don't hear it after 10 mph due to engine and exhaust noise
Can not be anything to bad if nothing's failed in this time just turn the radio up lol
4Random squeel from rear  Empty Re: Random squeel from rear on 21st June 2015, 2:12 pm
Keensie
I would say it's more of a rotational squeel doesn't matter if i'm turning or on/off the gas and with the brakes on.I've even pushed the car and heard it but trying to pin point where it comes from is impossible but i have noticed it only happens after a 30min drive so i'm thinking heat transfer from the rear brakes maybe causing something to squeel.
5Random squeel from rear  Empty Re: Random squeel from rear on 21st June 2015, 3:26 pm
I would say if it happens after driving 30mins possibly the brake pads touching the discs ????
6Random squeel from rear  Empty Re: Random squeel from rear on 12th July 2015, 5:18 pm
Keensie
I've removed the hub and the bearing is shot just need to get the new one pressed in and it's sorted.
7Random squeel from rear  Empty Re: Random squeel from rear on 12th July 2015, 9:51 pm
^ persistence paid off in end then ...
8Random squeel from rear  Empty Re: Random squeel from rear on 19th July 2015, 9:37 am
Keensie
If you have ABS and it's stuck in the hub assembly like mine was just disconnect it and remove it with the hub as the bearing can still be pressed in no problem.
