Gtir Motorsport club » Tech room » Help and Advice » brake pipe end size
brake pipe end size
1brake pipe end size Empty brake pipe end size on 29th June 2015, 7:06 am
luke s
Hi I'm going to replace a brake line to the rear wheel but what size is the end I need please, alsoisthe pipe 3/16?
Cheers guys
2brake pipe end size Empty Re: brake pipe end size on 29th June 2015, 12:13 pm
3/16 pipe.
M10 1mm pitch fittings, best getting matched ones short length & matching short unthreaded nose as longer unthreaded nose ones result in not a lot of caught thread & not really a sound job.
fittings & pipe easily available & decent motor-factors should have these & also eBay if needed.
3brake pipe end size Empty Re: brake pipe end size on 29th June 2015, 1:00 pm
grim_d
grim_d
As above, what you are looking for is "no lead" short fittings, they are threaded all the way.
Demon tweeks was the only place I could find brass ones.
4brake pipe end size Empty Re: brake pipe end size on 29th June 2015, 5:11 pm
luke s
Brilliant cheers guys after more thought I might reuse the ends and run anew brake pipe frontto back that wy theres no joins and I know the ends will be fine too
