Gtir Motorsport club » Tech room » Help and Advice » Erm,help needed
Erm,help needed
1Erm,help needed Empty Erm,help needed on 30th June 2015, 1:59 pm
houghy_1
I need some help,I'm losing the plot!
I've matched up all the plugs that I can before putting the engine back in but I'm left with 2 that I don't know...
Firstly what connects to the starter motor plug??...
And secondly where does this go,all sensors and the 2 blades are on round the back of the block but I'm left with this connector and not knowing what connects to the starter.
This is what happens when you take an engine out 2 years ago!
Thanks,matt
Erm,help needed DSC_0295
2Erm,help needed Empty Re: Erm,help needed on 30th June 2015, 6:08 pm
Gtirchris
Isn't that the wire that goes on to the starter solenoid mate?
3Erm,help needed Empty Re: Erm,help needed on 30th June 2015, 6:10 pm
Can you put multimeter on it and try cranking?? If it'll go live that's your tickle wire for starter
4Erm,help needed Empty Re: Erm,help needed on 30th June 2015, 11:00 pm
houghy_1
Engines currently out again,it's going back in 2moro again.
Can u post a pic of where it should go?
Also I can't find a mating plug for the starter motor,I must be missing something!
5Erm,help needed Empty Re: Erm,help needed on 30th June 2015, 11:06 pm
Well tbh i haven't any pics of it and on starter you're looking for just spade terminal (no plug as such) and usually it goes together with main battery + to starter (hope it makes sense) can you put foto of your starter?? I'll try to get one tomorrow but it's quite hard to get to it...
6Erm,help needed Empty Re: Erm,help needed on 30th June 2015, 11:21 pm
houghy_1
Yeah I will do,engines still out.
Like I said it's my own fault,I'm just learning my car again after nearly 2 years
7Erm,help needed Empty Re: Erm,help needed on 1st July 2015, 7:29 am
It might also go on one of the sensors (water) around the back of the engine near the oil filter, item # 14 in this diagram
http://nissan4u.com/parts/sunny/er_n14/1990_11/type_23/exhaust_and_cooling/water_pump_cooling_fan_thermostat_water_hose_and_piping/illustration_1/
8Erm,help needed Empty Re: Erm,help needed on 1st July 2015, 8:08 am
houghy_1
Nope there's the blue water sensor with a blade top right of the back of the engine that's done the blade near the oil cooler is done aswell.
I don't know if I've missed an earthing blade off somewhere?
I'll post some pics in 5 mins
9Erm,help needed Empty Re: Erm,help needed on 1st July 2015, 8:34 am
If you still have the infamous v bracket check if you've got any short wire there (like small extension)
10Erm,help needed Empty Re: Erm,help needed on 1st July 2015, 8:58 am
houghy_1
Erm,help needed DSC_0326
Y bracket went long ago. The starter motor has its ring done up from the battery.
Do these 2 fit together? I just don't wanna connect things wrong :-/
It's just,with them it not being a mating plug type.
11Erm,help needed Empty Re: Erm,help needed on 1st July 2015, 9:51 am
Unfortunately I've got top mount and y bracket still on so I can't see anything from what i remember that looks ok... Usually exciter wire is single wire on the same loom what main battery feed
https://bbmgarage.co.uk/
12Erm,help needed Empty Re: Erm,help needed on 1st July 2015, 11:18 am
Det sensor ??
13Erm,help needed Empty Re: Erm,help needed on 1st July 2015, 11:48 am
houghy_1
All other sensor plugs are used,thankfully they all are either colour coded or have lugs on them in specific places so they can't be mixed up and come out of the loom at the right places.
So it's mostly common sense.
14Erm,help needed Empty Re: Erm,help needed on 2nd July 2015, 11:47 am
matt that one you have your pinky pointing at looks like the connector to speedo sensor on top of transferbox
the single spade connection goes to starter solenoid its a black and white wire which I think is the colour of the one you are on about
btw posted the seals out thjs morning for you, sorry for delay fella
15Erm,help needed Empty Re: Erm,help needed on 2nd July 2015, 7:48 pm
houghy_1
@GTI-R US wrote:matt that one you have your pinky pointing at looks like the connector to speedo sensor on top of transferbox
Thanks Bob :-)
Well I've connected them together,the speedo sensor is already connected by the way.
Yes it's a black n white so I've connected them.up.
