Gtir Motorsport club » Tech room » Help and Advice » Air bubbles
Air bubbles
1Air bubbles Empty Air bubbles on 9th July 2015, 6:06 pm
scotty6860
scotty6860
All right Lads before I go mad can any on think of any thing that would put air in to the colling system car has had a new head gasket fitted
2Air bubbles Empty Re: Air bubbles on 9th July 2015, 6:17 pm
scotty6860
scotty6860
I have no smoke coming out of the exhaust the oil is fine
3Air bubbles Empty Re: Air bubbles on 9th July 2015, 6:48 pm
Split hose .... crack in the head ...
4Air bubbles Empty Re: Air bubbles on 9th July 2015, 6:51 pm
scotty6860
scotty6860
Hoping not a crack in the head but could be a split hose as there is warter on the floor now just to find where it is coming from think I need a pressure tester
5Air bubbles Empty Re: Air bubbles on 9th July 2015, 7:32 pm
It could be we a hose clamp has cut into it or similar ....fingers crossed for you mate ....
6Air bubbles Empty Re: Air bubbles on 9th July 2015, 7:35 pm
Did you bleed the cooling system fully after replacing the head gasket?
7Air bubbles Empty Re: Air bubbles on 9th July 2015, 7:42 pm
scotty6860
scotty6860
Yes mate fully bled it and every thing was fine been run and drive a few times then yesterday started to over heat and noticed bubbles again but when I come home from work there is warter on the floor
8Air bubbles Empty Re: Air bubbles on 9th July 2015, 8:21 pm
MartyMG
MartyMG
Could be the head gasket? When mine was going i got bubbles in my expansion tank after a drive & if i ragged it, it would overflow some coolant. Sad
9Air bubbles Empty Re: Air bubbles on 9th July 2015, 8:34 pm
scotty6860
scotty6860
Will have a good look if it is the head gasket again then I am taking the whole engine out go for a full rebuild
10Air bubbles Empty Re: Air bubbles on 9th July 2015, 10:09 pm
Sorry didn't answer the phone today Scott but will call you tomorrow at some stage, just been ultra busy.
If there is water on the floor then odds are you have split a hose fella.
If you've lost coolant through a leak in hose or whatever then the coolant will drop and be replaced by air in the sealed system.
When the coolant expands when hot it will over pressurise the cap and go into the expansion bottle, if it's very hot that will fill up and will be lost through the overflow on expansion which in turn will put even more air into the sealed system.
So it's a catch 22 really, you need to find the leak first and cure that then re-bleed the system purging the air out.
Don't use it if it's boiling up or you'll cook the engine and blow another head gasket, or warp / crack the head
