Gtir Motorsport club » Tech room » Help and Advice » Multiple GTIR Questions
1Multiple GTIR Questions Empty Multiple GTIR Questions on 26th July 2015, 6:52 pm
joetheeskimo
joetheeskimo
Got a few questions so decided to number them below,
1 - Some of the manifold studs have come out of the block and the thread is rounded, what are my options should i drill it out and tap for a larger bolt or helicoil the block
2 - Are the wheel bearings the same all round or are the front wheel bearings specific for the front.
3 - How do you remove the seals from the front hubs, im trying to replace the bearings.
4 - Im trying to replace the gear linakge seal on the gearbox, i need to take the pressed pin out of the linkage. Whats the best way to get it out, should i drill it out and replace with a nut and bolt
5 - Where can i get knock sensor mating connector from.
THanks
2Multiple GTIR Questions Empty Re: Multiple GTIR Questions on 26th July 2015, 7:25 pm
1. I helicoiled one of mine 9 years ago and still fine to this day. I gather you mean the threads stripped in the cylinder head?, if so then I would use a helicoil, think I used a M10 as I tried to drill the old snapped stud out and made a right hash of it!
2. All the same, just bought four myself from ICP and funnily enough I asked the same question.
3. I used a long flat screwdriver tucked beneath seal lip and popped it out, small pry bar would also work.
4. I need to know this myself Very Happy
5. not sure
3Multiple GTIR Questions Empty Re: Multiple GTIR Questions on 26th July 2015, 7:58 pm
4, those pins can be a cock, if won't budge then drilling only route. I had some success using a hydraulic bearing puller adapted to press pin.
5. Those knock sensors are used on a lot of nissans & some renaults so you could possibly pull a connector from a breakers yard, expect can be found online, will have a look.
4Multiple GTIR Questions Empty Re: Multiple GTIR Questions on 26th July 2015, 8:10 pm
5 if you get really stuck it's only 1 wire the left pin on the knock sensor the very small spade connectors will fit
5Multiple GTIR Questions Empty Re: Multiple GTIR Questions on 26th July 2015, 8:53 pm
5. do have connectors on eBay but unfortunately didn't see one direct in uk so not great price with shipping.
I would salvage one from breakers or solder cable tail into the sensor & then add a new connector to tail & loom .
6Multiple GTIR Questions Empty Re: Multiple GTIR Questions on 27th July 2015, 12:53 am
Easy to get out with a drift punch, which will allow you to re-use the pin.  You need a set of these
http://www.ebay.co.uk/sch/i.html?_from=R40&_trksid=p2050601.m570.l1313.TR0.TRC0.H0.Xsplit+pin+drift+set.TRS0&_nkw=split+pin+drift+set&_sacat=0
They come in handy for multiple uses so well worth buying a set.
7Multiple GTIR Questions Empty Re: Multiple GTIR Questions on 27th July 2015, 1:35 am
I've had a couple of those pins seized, punch wasn't working so used hydraulic puller as press on pin & left it under pressure for few hours & tighten ram periodically, sprayed with release oil and eventually they moved without any fuss or abuse.
8Multiple GTIR Questions Empty Re: Multiple GTIR Questions on 27th July 2015, 10:08 am
4. Have a closer look at the pin as mine had a pin inside other pin.
9Multiple GTIR Questions Empty Re: Multiple GTIR Questions on 27th July 2015, 9:33 pm
That how they been on ones I done 2 seloc spring pins one inside other for better strength.
