Gtir Motorsport club » Tech room » Help and Advice » Synapse bov
Synapse bov
1Synapse bov  Empty Synapse bov on 22nd August 2015, 3:06 pm
Rscozzy
Need help fitting this well confused http://www.synapseengineering.com/support/faq/pdf/SB%20BOV%20manual.pdf
Not sure where to put pipe for boost source/Compressor signal
2Synapse bov  Empty Re: Synapse bov on 23rd August 2015, 4:55 pm
Rscozzy
I guess no one else knows how to fit 1
3Synapse bov  Empty Re: Synapse bov on 23rd August 2015, 5:03 pm
I havent ever seen one like it before. So wouldnt like to comment on how i think it might be plumbed in.
4Synapse bov  Empty Re: Synapse bov on 23rd August 2015, 5:11 pm
Boost source I'm guessing it would be your waste gate control pipe or something like pipe for boost gauge well that's what I'd do anyway
If you are after good vac source you could try to plumb it in mcm way (4 small pipes after throttles) https://www.youtube.com/watch?v=En91CuhPqjI
https://bbmgarage.co.uk/
5Synapse bov  Empty Re: Synapse bov on 23rd August 2015, 8:15 pm
Not similar to hks wher you just blank one of those off
6Synapse bov  Empty Re: Synapse bov on 23rd August 2015, 8:19 pm
Rscozzy
Am just not sure where to pipe the port c
7Synapse bov  Empty Re: Synapse bov on 23rd August 2015, 8:41 pm
Based on the diagram id use one of the vacuum ports on the manifold or similiar to the video above. For port C I'd say if the compressor housing on the turbo has a port use that or tap a new port into the intercooler pipe close to the turbo? Haven't seen one like that before though.
Synapse bov  Image
