Gtir Motorsport club » Tech room » Help and Advice » Tie rods
Tie rods
1Tie rods Empty Tie rods on 6th September 2015, 10:07 pm
Would anyone know if the inner tie rods are M14x1.5 (rack end) and M12x1.25 (ball joint end)?
2Tie rods Empty Re: Tie rods on 12th September 2015, 9:28 am
Does anyone know a reliable website that I can use to compare to tie rod lengths and threads? Its annoying getting info from all different sources.
3Tie rods Empty Re: Tie rods on 12th September 2015, 7:22 pm
Gtirchris
Here you are Woody, I've just measured one of my new ones for you.
Overall length is 280mm
Outer thread length is 54mm
Outer thread size is M14x1.5
Inner thread length is 15mm
Inner thread size is M16x1.0
Distance between inner socket and outer thread is 179mm
Nissan part number is 48521-60Y05
4Tie rods Empty Re: Tie rods on 12th September 2015, 8:06 pm
Rep point for being so helpful chris .....
5Tie rods Empty Re: Tie rods on 12th September 2015, 8:22 pm
Thanks heaps for this Chris Smile
6Tie rods Empty Re: Tie rods on 12th September 2015, 10:04 pm
Gtirchris
No worries fella, glad to help you out Cool, thanks for the rep points lads Wink
7Tie rods Empty Re: Tie rods on 11th April 2016, 9:26 am
Well im trying to remove the inner tie rod, its got a metal lock tab which looks like im going to fook getting off. My new tie rods didn't come with the locking tab, can I just use some thread lock and all good?
8Tie rods Empty Re: Tie rods on 11th April 2016, 9:30 am
Also on the passenger side there seems to be a metal washer and a rubber o-ring just floating around on the rack shaft, im guessing this isn't normal. Ive touched a rack before Laughing
EDIT - if you have pictures of your rack please show me Laughing Laughing
9Tie rods Empty Re: Tie rods on 11th April 2016, 7:51 pm
https://www.gtir-motorsport-club.com/t5106-steering-rack-inner-ends
if lucky/careful you can reuse clinch washers, if not get new P/N 4863550A06
not sure on your oring-washer scenario
diag of rack parts below >
Tie rods Gtir_steering_rack
10Tie rods Empty Re: Tie rods on 11th April 2016, 9:05 pm
Thanks mate, I'll have another look. I actually found the clinch washers that came with the rods, they look completely different though.
11Tie rods Empty Re: Tie rods on 12th April 2016, 6:58 am
Got the old tie rod off this arvo. This is what I was talking about, it's actually a plastic washer. It would be part of the rack seal.
Tie rods Image
