Gtir Motorsport club » Tech room » Help and Advice » Problems with poly bushes
1Problems with poly bushes Empty Problems with poly bushes on 7th September 2015, 6:44 pm
joetheeskimo
joetheeskimo
So i fitted poly bushes to my front wishbones. Trying to get them on the car seems impossible. The front bush in the arm lines up with the hole one side but not the other, ive tried prying it with screw driver and jacking the arm up still no joy. It was so tight to get the front bush to locate into the chassis.
Also the rear bush is so big and bulky it doesnt sit flush on the chassis it does fit. Anyone else fitted these poly bushes and had sucess getting the arm to fit to the car. The clamp that sits over the bush seems to small to fit over it at all.
Problems with poly bushes 20150727_170847
2Problems with poly bushes Empty Re: Problems with poly bushes on 7th September 2015, 7:57 pm
Which make mate ?
3Problems with poly bushes Empty Re: Problems with poly bushes on 8th September 2015, 4:14 pm
joetheeskimo
joetheeskimo
powerflex on the front and superpro on the rear
4Problems with poly bushes Empty Re: Problems with poly bushes on 8th September 2015, 8:57 pm
I have superpro bushes in my front control arms and they were fine mate
5Problems with poly bushes Empty Re: Problems with poly bushes on 8th September 2015, 8:58 pm
Where did you get the bushes from? double checked the part numbers?
6Problems with poly bushes Empty Re: Problems with poly bushes on 9th September 2015, 7:46 am
Hardy172cup
Hardy172cup
Those rear bushes your trying to fit are meant for a gti, the gtir ones have a bulge on the top that fits into the shape on the floorpan.
7Problems with poly bushes Empty Re: Problems with poly bushes on 9th September 2015, 11:40 am
As bill says, front bush on R has chamfered top to fit into locating well in floorpan.
Problems with poly bushes SPF1374_AK
R ones are same like n13, looks like you been supplied wrong rear bush & possibly front bush too perhaps !
