Gtir Motorsport club » Tech room » Help and Advice » selecting gears
selecting gears
Go to page : 1, 2, 3, 4  Next
Go down  Message [Page 1 of 4]
1selecting gears Empty selecting gears on 8th September 2015, 1:10 pm
Just been out in the pulsar and the gear change started to get botchy.
Then when pulling up at lights first gear was hard to get in. I had to put it into second and then it would go into first.
While driving the gearstick is moving when i go on the gas and off it.
Pulled up at home and it is hard to get it into any gear now.
I dont think its clutch or slave.
It feels like something has come loose on the gear linkage.
I will have to have a good look tomorrow.
Has anyone else had this happen?
2selecting gears Empty Re: selecting gears on 8th September 2015, 5:25 pm
Is it the spring underneith people have trouble with stu ?
3selecting gears Empty Re: selecting gears on 8th September 2015, 6:13 pm
Im not sure Johnny. I need to borrow my brothers jack and get under the car and check. Im hoping its something simple.
4selecting gears Empty Re: selecting gears on 8th September 2015, 6:19 pm
It's only one bolt on the gear linkage though isn't it.....sounds more like a clutch problem...or internally on the gearbox....
5selecting gears Empty Re: selecting gears on 8th September 2015, 6:47 pm
It isnt gearbox issues or clutch. I cant get it in gear with engine off unless i jiggle the gearstick and then it will go in gear but notchy.
Well im hoping it isnt a gearbox off job anyways lol
6selecting gears Empty Re: selecting gears on 8th September 2015, 7:19 pm
GTIR James
Had the same. Gear selector centre spring. Does the selector spring back to the neutral position from the left & right?
7selecting gears Empty Re: selecting gears on 8th September 2015, 7:42 pm
Just had a look James. If i push the stick to the right it pushes back to the centre. If i push it to the left it doesnt. Its sloppy.
Plus after messing about with it just i can get all gears again.
8selecting gears Empty Re: selecting gears on 8th September 2015, 7:55 pm
My money's on gearbox....me and gearboxes have a 'thing' going on atm Razz
9selecting gears Empty Re: selecting gears on 8th September 2015, 7:57 pm
@PartyPete wrote:My money's on gearbox....me and gearboxes have a 'thing' going on atm Razz
It isnt gearbox lol i only jiggled the gearstick side to side and the gears came back. It has to be selector issue.
10selecting gears Empty Re: selecting gears on 8th September 2015, 8:08 pm
I'm going to go and stick some pins in my broken gearbox like a voodoo box and see what happens to yours Razz sorry stu
11selecting gears Empty Re: selecting gears on 8th September 2015, 8:12 pm
Hahaha i hve a force field around my car so your voodoo wont do jack Laughing
Its called a proximity force field haha
12selecting gears Empty Re: selecting gears on 8th September 2015, 8:16 pm
The gearbox killing force is strong in me....break your gearbox I will Razz
13selecting gears Empty Re: selecting gears on 8th September 2015, 8:18 pm
Haha i have just bought a steering wheel lock so my security is very high lol
14selecting gears Empty Re: selecting gears on 8th September 2015, 8:22 pm
It Won't protect your gearbox Twisted Evil !!! On a serious note I hope it is to do with your linkage...you will no more when you've jacked it up, fingers crossed something has worked loose
15selecting gears Empty Re: selecting gears on 8th September 2015, 8:24 pm
Thanks. Im pretty sure its the linkage Smile
16selecting gears Empty Re: selecting gears on 8th September 2015, 8:30 pm
probably worth doing the linkage bushes, the return spring & mod the rubber mount bush to solid as makes a huge huge difference & hopefully will cure your problems & make gear change feel like new .
few threads on hear with parts links/numbers .
17selecting gears Empty Re: selecting gears on 8th September 2015, 8:40 pm
Thanks all.
Will have a look for those links thanks MrB.
18selecting gears Empty Re: selecting gears on 8th September 2015, 9:27 pm
^ here's one thread to get u started stu >
https://www.gtir-motorsport-club.com/t3088-linkage-bushes
19selecting gears Empty Re: selecting gears on 8th September 2015, 9:28 pm
Thanks mate Smile
20selecting gears Empty Re: selecting gears on 19th September 2015, 11:53 am
Just managed to have a look at the gear linkage and the spring and plastic bush are fine.
The problem keeps moving from gears.
I could get all gears to engage then while going through the gears i couldn't get it to engage 1st. Then i could and i couldnt get reverse.
Then i couldnt get 1st. 3rd and 5th to engage. But 2nd. 4th and reverse were okay.
Then i could get all gears to engage again.
And so on and so on.
Very random gear obstruction.
Sometimes the gear wont go in at all and sometimes you have to oush it a little harder and it slips in. Other times it just slips in.
What the feck is going on.
21selecting gears Empty Re: selecting gears on 19th September 2015, 12:35 pm
Supernova
Alignment issue? I've just ordered one of those bushes from ebay as I have a similar issue to you but not quite as bad, sometimes struggle to get in first and reverse most of the time it's fine.
22selecting gears Empty Re: selecting gears on 19th September 2015, 1:15 pm
Maybe it is that bush then. It all looked good. Wont hurt to swap that over first. Its the easiest and cheapest option.
Thanks.
23selecting gears Empty Re: selecting gears on 19th September 2015, 4:56 pm
Supernova
I'll have mine fitted by next weekend so I'll let you know if it's any good.
The way I see it, it can't hurt replacing items like that on a 20 year old car.
24selecting gears Empty Re: selecting gears on 19th September 2015, 7:12 pm
could be the gear stabiliser arm bolts have come loose or the bush that holds the stabilizer arm to bracket on transferbox
Happened to rich's car at snetterton the other day and had to force the bush back into the holder
25selecting gears Empty Re: selecting gears on 19th September 2015, 8:54 pm
@Supernova wrote:I'll have mine fitted by next weekend so I'll let you know if it's any good.
Thanks.
Yeah i may aswel change it as its an old bush...
@GTI-R US wrote:could be the gear stabiliser arm bolts have come loose or the bush that holds the stabilizer arm to bracket on transferbox
Thanks Bob. I will get under it again and check everything.
Back to top  Message [Page 1 of 4]
