Gtir Motorsport club » Tech room » Help and Advice » New Radiator
New Radiator
1New Radiator Empty New Radiator on 19th September 2015, 10:06 am
Supernova
After being a bit of a clumsy git this morning I've managed to break my radiator, I've snapped the top outlet flange off. I think I can repair it temporarily but I'm going to need a new rad.
Which one should I go for and where is the best place to buy it?
2New Radiator Empty Re: New Radiator on 19th September 2015, 12:05 pm
Standard or uprated standard I would say  e bay one but a shop seller sell the same thickness as a sunny so slightly thicker than a pulsar but totally standard fit with clearance issue around £45 I think or a local motor factors will supply the same
Uprated I am a fan of mishimoto alloy rads for the money  great fit and again very few clearance issues unlike say the 50mm kyo
3New Radiator Empty Re: New Radiator on 19th September 2015, 12:33 pm
Supernova
Ideally i'll put an uprated one on as it makes more sense to do it properly.
I've been looking at this one which seems good value for money http://www.ebay.co.uk/itm/350573955997?ssPageName=STRK%3AMEBIDX%3AIT&fromMakeTrack=true
Will I need slimline fans as their isn't much room between the standard one and my intercooler as it stands.
4New Radiator Empty Re: New Radiator on 19th September 2015, 4:12 pm
Is your rad pushed further towards the engine than oem position?. I've also been looking at those rads, black looks nicer. Could get this one Check out this item I found on eBay: http://pages.ebay.com/link/?nav=item.view&id=171874110390&alt=web for 45quid more comes with fan shroud and fans
5New Radiator Empty Re: New Radiator on 19th September 2015, 4:39 pm
Supernova
As far as I'm aware the rad is in it's standard position. Well I've already purchased the one in the link I put up. Hopefully it all fit's ok but I imagine I can make it fit I'm unsure about the fans but the link that you provided has the fans on the opposite side so thats an option.
6New Radiator Empty Re: New Radiator on 19th September 2015, 5:13 pm
You could have it pushing air through the rad or pulling the air like oem. I'd do it oem for ease unless you have a wacking great big turbo and don't have much room? Slim line fans are dirt cheap anyway, i bought ebay specials for 30quid but the shroud looks cool. Think i will be adding it to my christmas list
7New Radiator Empty Re: New Radiator on 19th September 2015, 5:17 pm
I have the same one as in the link with the slimline fans on the inside ...
8New Radiator Empty Re: New Radiator on 19th September 2015, 5:19 pm
Is it a good fit and sturdy? Looks decent in the pics
9New Radiator Empty Re: New Radiator on 19th September 2015, 5:26 pm
pull fans is the preferred setup.
10New Radiator Empty Re: New Radiator on 19th September 2015, 5:52 pm
No problems fitting will 100% need the slimline fans as its to tight otherwise against the turbo ...as b said pull fans imo are better ...
11New Radiator Empty Re: New Radiator on 19th September 2015, 8:56 pm
@Mr B wrote:pull fans is the preferred setup.
Indeed but in many setups room between the rad and the turbo/manifold is an issue with the little cars Sad
12New Radiator Empty Re: New Radiator on 21st September 2015, 8:39 am
ive got a japspeed one from ebay, decent rad but damn was it a tight fit, its also 50mm and im using the standard fans with no issues for over a year
13New Radiator Empty Re: New Radiator on 21st September 2015, 10:31 am
Supernova
That's good news where did you mount your fans? Between the intercooler or between the turbo?
14New Radiator Empty Re: New Radiator on 21st September 2015, 12:07 pm
@Supernova wrote:That's good news where did you mount your fans? Between the intercooler or between the turbo?
if that was aimed at me, the fans were in the original position, no modifications to anything at all, just removed fans from old rad and placed them on the new rad, it was a really tight fit and the only issue i had was getting it all past the aircon pipe but there still a bit of space between the turbo and the fans
15New Radiator Empty Re: New Radiator on 22nd September 2015, 3:48 pm
Supernova
Rad has turned up today but I seem to have a couple of outlets on the bottom of the rad that ain't their on the standard one, anybody have any idea what their for?
New Radiator WP_20150922_16_38_37_Pro_zps7ra1yc86
16New Radiator Empty Re: New Radiator on 22nd September 2015, 4:16 pm
They don't matter.ignore them. Think they are for steering cooling or heating or something. Anyhow they are connected together so won't leak. I'm selling mine at the mo and never connected them up.
17New Radiator Empty Re: New Radiator on 22nd September 2015, 4:25 pm
Yea power steering cooling is what I heard
18New Radiator Empty Re: New Radiator on 23rd September 2015, 8:56 am
Is that because they use the same radiator on other cars where the P/S cooler part would be used?
19New Radiator Empty Re: New Radiator on 23rd September 2015, 11:48 am
^ I think the y10 sunny has same radiator as gtir & also the b13 sentra sr20 has same or close enough match to fit.
Would assume you right in thinking these rads designed fit several models. I would of thought the integral cooler tube was for auto trans fluid, most oem pas coolers are simple small air cooler tubes .
20New Radiator Empty Re: New Radiator on 25th September 2015, 1:58 pm
Supernova
New rad installed today I must say I'm quite impressed at the quality for the price.
New Radiator WP_20150925_11_37_05_Pro_zpshlxoq7gy
New Radiator WP_20150925_11_38_56_Pro_zpsrvpjdcdm
New Radiator WP_20150925_12_43_40_Pro_zpsc219dkom
New Radiator WP_20150925_12_43_54_Pro_zpshn1rr5fo
One question I have though is the new rad came with a 1.3 bar cap and I have just brought a hks 1.1 bar cap so I have fitted that because it looks better. Any reason why I should run the 1.3 rather than the 1.1?
21New Radiator Empty Re: New Radiator on 25th September 2015, 6:19 pm
Stick with 1.1, too much water pressure can be a bad thing & lead to nasty problems.
22New Radiator Empty Re: New Radiator on 25th September 2015, 6:32 pm
ive used nismo rad caps in all my gtirs since 1999 yet to have a problem with increased pressure
23New Radiator Empty Re: New Radiator on 25th September 2015, 7:33 pm
0.9 is standard, 1.1 is sensible but 1.3 is not really needed by majority who use them & all they do is potentially overstress cooling system components ...
