Gtir Motorsport club » active members adverts » Parts Wanted » Side skirt plug/grommets
1Side skirt plug/grommets Empty Side skirt plug/grommets 23rd September 2015, 6:12 am
bolf
bolf
Im getting new sills welded in and need a few bits.
Im after the plugs off the side skirts and the gromets off the sill, about 10 would do.
Thanks Gav.
2Side skirt plug/grommets Empty Re: Side skirt plug/grommets 23rd September 2015, 11:15 am
If you can't get second hand / used ones then these are the part #s from Nissan
Clip 01553-06841 (plug female - body piece) x 20
Clip 01553-06851 (plug male - side skirt piece) x 20
Clip-trim 01553-06611 (sill grommet female - kick plate) x 10
3Side skirt plug/grommets Empty Re: Side skirt plug/grommets 24th September 2015, 6:13 am
bolf
bolf
Thanks mate, I will give them a call.
4Side skirt plug/grommets Empty Re: Side skirt plug/grommets 9th November 2015, 9:35 pm
#28 7689550C00 would the trim between the side skirt and the sill correct?
http://nissan4u.com/parts/sunny/el_n14/1991_3/type_49/body_side_and_rear/body_side_moulding_and_body_side_fitting/illustration_1/
