Gtir Motorsport club » Tech room » Help and Advice » Rear Diff
Rear Diff
1Rear Diff Empty Rear Diff on 23rd September 2015, 9:50 pm
While Ive got my sub frame out, thought I better look at the rear diff.
I'm going to replace the drive shaft and tailshaft seals, change the oil. Anything else that I should do? or should I be stripping it down while its out?
2Rear Diff Empty Re: Rear Diff on 24th September 2015, 1:22 am
Was there anything wrong with it prior to removal?
If not, no sense in playing with something that is working ok.
Seals yes. Otherwise, plug and play Very Happy
3Rear Diff Empty Re: Rear Diff on 24th September 2015, 1:38 am
I don't think so, one seal looks greasy but in saying that never drove it hard when it was on the road.
I have a Nismo rear diff sitting in a box at home but thought I wouldn't install it until I have a proper front diff.
4Rear Diff Empty Re: Rear Diff on 24th September 2015, 1:46 am
By the sounds of it, just replace the seals for now.
That will keep you going until you are ready to put in the Nismo.
5Rear Diff Empty Re: Rear Diff on 24th September 2015, 3:39 am
Sounds like the way to go, thanks mate thumbsup
6Rear Diff Empty Re: Rear Diff on 24th September 2015, 7:07 am
GTIR James
The drive shaft seals are not available from nissan anymore so will req sizing up to find replacements.
7Rear Diff Empty Re: Rear Diff on 24th September 2015, 7:16 am
Really? I thought they would have been Shocked
8Rear Diff Empty Re: Rear Diff on 24th September 2015, 8:49 am
Pulsarmoley (pete) is the man to talk to as pretty sure he sorted someone else out diff seals as hes company use the supplier or something like that ....
9Rear Diff Empty Re: Rear Diff on 24th September 2015, 8:31 pm
Thanks Leighton I'll be looking in to it today
10Rear Diff Empty Re: Rear Diff on 24th September 2015, 8:47 pm
http://nissan4u.com/parts/sunny/er_n14/1990_11/type_23/power_train/rear_final_drive/
Is it #9 and #40 I need?
11Rear Diff Empty Re: Rear Diff on 24th September 2015, 9:24 pm
From the diagram i would say so ...
12Rear Diff Empty Re: Rear Diff on 24th September 2015, 9:27 pm
Thanks Smile I hate finding part numbers lol
13Rear Diff Empty Re: Rear Diff on 24th September 2015, 9:33 pm
Nissan still do those seals, they used on a shit load of Nissans .
Main problem is lazy c*nts at nissan parts like using the 'no longer available' as easy way out when presented with something odd like the R, UK Nissan Parts being super lazy f00kers.
If can't get them from nissan for whatever reason then any decent bearing shop or super decent motor-factors can match them from numbers you find on the seals.
14Rear Diff Empty Re: Rear Diff on 24th September 2015, 9:45 pm
Thanks B, I'll see how I go when I call them up today. Do those part numbers look like the right ones?
15Rear Diff Empty Re: Rear Diff on 24th September 2015, 10:26 pm
Look right to me ...
Still find them for sale online ...
Rear Diff 2012-7-5-702-5212030890
   Brand:NISSAN
   Part Number(s):3834221000
   ProductName:Shaft Seal, differential
   Inside Diameter:32 mm,1.26 in
   Outside Diameter:52.27 mm,2.058 in
   Width:11 mm,0.433 in
Rear Diff 2012-7-5-776-5231949453
   Brand:NISSAN
   Part Number(s):38189U3000
   Inside Diameter:35 mm,1.378 in
   Outside Diameter:67.31 mm,2.65 in
   Width:11.99 mm,0.472 in
16Rear Diff Empty Re: Rear Diff on 24th September 2015, 10:53 pm
Cheers mate, no idea where you dig all this stuff up from Laughing
17Rear Diff Empty Re: Rear Diff on 25th September 2015, 11:05 am
Professor Google Idea's
18Rear Diff Empty Re: Rear Diff on 25th September 2015, 11:13 am
Hes one brainy bloke that mr google i reckon he must have a wheel barrow to carry the big head of hes ....
19Rear Diff Empty Re: Rear Diff on 25th September 2015, 11:17 am
@nomad wrote:Hes one brainy bloke that mr google i reckon he must have a wheel barrow to carry the big head of hes ....
Not sure why. But this made me think of vis.
Rear Diff 2015-09-25-12-15-49-2037313347_zpsqbuiilqa
Laughing
20Rear Diff Empty Re: Rear Diff on 25th September 2015, 11:37 am
Google & parts databases & stuff I have had to source over the years...
21Rear Diff Empty Re: Rear Diff on 25th September 2015, 12:30 pm
Wow vis now that takes me back ....
22Rear Diff Empty Re: Rear Diff on 25th September 2015, 9:28 pm
Those are some large testicles Laughing
23Rear Diff Empty Re: Rear Diff on 28th September 2015, 1:30 am
Now that I've removed the diff I'm going to decrease it and give it some fresh paint. Is there something I can run through the inside of the diff to give it a good clean? Or should I just simply replace the oil and away I go.
24Rear Diff Empty Re: Rear Diff on 28th September 2015, 6:27 am
Personally I would just replace oil
25Rear Diff Empty Re: Rear Diff on 28th September 2015, 7:27 am
Thanks johnny thumbsup
