Gtir Motorsport club » Tech room » Help and Advice » Compression test
Compression test
1Compression test Empty Compression test on 28th September 2015, 8:04 pm
Rscozzy
Done a compression test all 4 reading 125psi is this good had a lot of white creamy stuff on rocker cover and forged breather system doesnt over heat but gets hot really fast fans working doesn't miss fire engine is ment to b forged
2Compression test Empty Re: Compression test on 28th September 2015, 8:33 pm
Forged breather system ? And has the car stood ?
3Compression test Empty Re: Compression test on 28th September 2015, 8:47 pm
Rscozzy
It was stood for 4 years in a barn been back on road 2 mth changed oil filters etc before running
4Compression test Empty Re: Compression test on 28th September 2015, 8:48 pm
Rscozzy
Forged breather system name on catch tank
5Compression test Empty Re: Compression test on 28th September 2015, 9:11 pm
Rscozzy
Forged motorsports
6Compression test Empty Re: Compression test on 28th September 2015, 9:21 pm
Now my forge oil separator I blocked the pipe off going back to the block as it was when left a few days getting Condensation in and oil was creamy then it was warming up when started and putting it into engine I was like this can not be good
7Compression test Empty Re: Compression test on 28th September 2015, 9:23 pm
Just out of interest what way did you comp test it and is it using water
8Compression test Empty Re: Compression test on 28th September 2015, 9:34 pm
Rscozzy
Removed spark plugs turned car over 125psi is loosing water I think but bleed system and seems to b ok not getting as hot just over 1/4 was 1/2 way befor bleeding
9Compression test Empty Re: Compression test on 28th September 2015, 10:45 pm
As said
You need to make sure air is out of the system as this will cause head to overheat which could cause cracking or best case scenario a blown h/g.
As Johnny said above, this time of year especially you are likely to get some form of condensation especially if the car is only doing round town short trips and not getting up to required temp to burn off any unsavoury deposits in the oil system.
When you did comp test did you remove all plugs at once or one at a time?
Also if the engine is forged have they used arp head studs by any chance?
10Compression test Empty Re: Compression test on 29th September 2015, 2:28 am
Rscozzy
Removed all spark plugs
11Compression test Empty Re: Compression test on 2nd October 2015, 5:47 am
Rscozzy
Head coming off got water in number 2 piston
Any advice on head removal and where to buy gaskets and hoses cheerd
12Compression test Empty Re: Compression test on 2nd October 2015, 6:17 am
Sorry am crap with links but hope this works
https://www.gtir-motorsport-club.com/t5630-buying-headgasket
13Compression test Empty Re: Compression test on 2nd October 2015, 6:19 am
And the workshop manual is on here ( the site)  more so for refitting onc the sequence torque settings etc
14Compression test Empty Re: Compression test on 2nd October 2015, 6:24 pm
Rscozzy
Ok cheers heads off but made a boo boo the two 8mm Alan bolts would indo so there a bit mashed got them out and then realised they don't hold head on Sad no I didn't read guide just dived straight so need two of them
