Gtir Motorsport club » Tech room » Help and Advice » Abs coming on
Abs coming on
1Abs coming on Empty Abs coming on on 5th October 2015, 6:27 pm
I've not done a fault code check yet but my abs is kicking in occasionally but only when I slow down from about 10 mph to come to a stand still. Any ideas?
2Abs coming on Empty Re: Abs coming on on 5th October 2015, 6:33 pm
I'd say it's one of abs sensor rings, as you coming to stop it looses signal and it thinks that this wheel has stopped. You' need to check there condition and gap between ring and sensor
https://bbmgarage.co.uk/
3Abs coming on Empty Re: Abs coming on on 5th October 2015, 7:01 pm
Im sure i have both front sensors if you need one. The plugs will need to be put on them tho. The scrap yard i had the hubs from had just pulled the metal spades out the plug..
Just cover the postage Wink
