Gtir Motorsport club » Tech room » Help and Advice » Head bolts
Head bolts
1Head bolts  Empty Head bolts on 18th October 2015, 2:01 pm
Rscozzy
What's standerd length of head bolts from new
2Head bolts  Empty Re: Head bolts on 19th October 2015, 1:10 pm
Sure this post has come up recently mate, not got time to search at the mo for it. Can try later
3Head bolts  Empty Re: Head bolts on 19th October 2015, 1:13 pm
Rscozzy
Ok cheers was just going to buy arp 1s but wasn't sure if I need to no length or if there 1size
4Head bolts  Empty Re: Head bolts on 19th October 2015, 3:11 pm
Thermal
Thermal
Have a read of Scott's adventures with ARP before you buy, see the post below.
https://www.gtir-motorsport-club.com/t4867-misfire
5Head bolts  Empty Re: Head bolts on 19th October 2015, 5:59 pm
Buy oem or blueprint, blueprint ADN17814 can be had at good price normally.
the standard bolts can clamp huge power.
6Head bolts  Empty Re: Head bolts on 19th October 2015, 8:28 pm
Many people have used arp with no problems on the R, others have had problems, seems a mixed bag really.
7Head bolts  Empty Re: Head bolts on 19th October 2015, 9:40 pm
^ yeh I think some maybe down to fitting (bit like par gearkit in early days of uk use) but I don't think they worth risk or the cost when standard bolts been good on many high 400 & 500 & beyond builds .
8Head bolts  Empty Re: Head bolts on 19th October 2015, 10:14 pm
Danny had arp on his and head lifted then he had 500plus and now just over 600 and he I am sure is on standard bolts and had no issues
9Head bolts  Empty Re: Head bolts on 19th October 2015, 10:50 pm
Don't use arp head studs if you want to avoid problems as they do not seat correctly in the block, they then unwind and you will have issues with head lifting. Many other marquees use them with no issues but then they generally run narrower less sturdy bolts (such as 200sx).
If you want some good head bolts we have some in stock from original engines which have only been used once and these can be re-used with no issues and will save you a fair few quid
