Gtir Motorsport club » Tech room » Help and Advice » Gear box rebuild
Gear box rebuild
1Gear box rebuild Empty Gear box rebuild on 23rd November 2015, 11:59 pm
GTi ARGHH
Hi, about to get a box built up (not by me) and need to get some things double checked.
Is this the correct part number for gear box input shaft seal ? 32113-03e00
These the correct part numbers for gearbox drive shaft seals: 33142-56e00 and 38342-56e00 ?
Also need all the bearings part numbers if possible, are they all listed here or are there anymore that will be needed?
http://nissan4u.com/parts/sunny/er_n14/1990_11/type_23/power_train/transmission_gear/illustration_1/
Any help would be much appreciated, and all info I gathered was found here, so keep up the good work people and thanks in advance for any input.
2Gear box rebuild Empty Re: Gear box rebuild on 24th November 2015, 12:36 am
yes that right numbers
pdf link for box seal below if you not seen it already
https://drive.google.com/file/d/0B7Ub2apq5-pfUlRubFhSN3M4cDQ/view
only 2 bearings are specific nissan, gearbox builder or bearing shop can get rest exact same spec/make . best wait & see what found wanted once job underway
ps: good username Very Happy
3Gear box rebuild Empty Re: Gear box rebuild on 24th November 2015, 10:36 pm
GTi ARGHH
@Mr B wrote:yes that right numbers
Thanks Mr B, thats great.
Yes, about my user name - you wouldnt believe the irony of it, thinking of changing it to GTi ARGHH 'k sake! Laughing
