Gtir Motorsport club » Tech room » Help and Advice » Timing chain tension
1Timing chain tension Empty Timing chain tension on 24th November 2015, 3:40 pm
Rscozzy
There's a little metal gasket what goes on timing chain tensioner doe I need it on because oil keeps leaking from it doing my head had it off 3 times
2Timing chain tension Empty Re: Timing chain tension on 24th November 2015, 7:48 pm
Run a bead of sealant around it. Thats what we did with mine.
3Timing chain tension Empty Re: Timing chain tension on 24th November 2015, 8:03 pm
Rscozzy
With or without metal gasket
4Timing chain tension Empty Re: Timing chain tension on 24th November 2015, 8:19 pm
We left the gasket in place.
5Timing chain tension Empty Re: Timing chain tension on 24th November 2015, 8:24 pm
Rscozzy
Ok cheers just had a look think have caught face with screw driver when taking it of but of a chip on it just where it's leaking
6Timing chain tension Empty Re: Timing chain tension on 24th November 2015, 8:25 pm
Rscozzy
Any ideas how to fix it
7Timing chain tension Empty Re: Timing chain tension on 25th November 2015, 6:28 am
I just bought a new tensioner and gasket. Gasket is a Nissan 13079-2J200 and it's metal with like rubber(ish) material.
Is there a top and bottom or can it be put on either way?
