Gtir Motorsport club » Tech room » Help and Advice » Starting problems
Starting problems
1Starting problems  Empty Starting problems on 29th November 2015, 8:11 pm
Rscozzy
been for a drive 20mins got back home turned car off
10 mins later came out to go to shop and it's just turning over won't fire done this a few times ..I have just put engine back in was thinking have got some connection wrong
2Starting problems  Empty Re: Starting problems on 29th November 2015, 8:19 pm
I would check ecu temp sensor & connector/wiring harness as I seen them bad causing serious over-fueling on hot start & also can keep fans running like other fault you reported .
3Starting problems  Empty Re: Starting problems on 29th November 2015, 8:25 pm
Did you change/ modify anything on the harness while it was out? Just making sure, so we know that it was untouched.
4Starting problems  Empty Re: Starting problems on 29th November 2015, 8:29 pm
Rscozzy
Have Changed temp sensor and thermostat done nothing to wiring harness is there two temp sensors1 I changed was 1 with spade connector
5Starting problems  Empty Re: Starting problems on 29th November 2015, 8:39 pm
^ you changed the sensor for the dash temp guage.
the ecu temp sensor has a 2pin plug .
6Starting problems  Empty Re: Starting problems on 29th November 2015, 8:54 pm
Spark plug spike
Spark plug spike
The red connector is the Ecu temp sensor, a bit of a fiddly job to change in situ but can be done.
Starting problems  Image10
7Starting problems  Empty Re: Starting problems on 29th November 2015, 9:03 pm
Spark plug spike
Spark plug spike
8Starting problems  Empty Re: Starting problems on 29th November 2015, 9:10 pm
Rscozzy
If I unplug it will car run ok
9Starting problems  Empty Re: Starting problems on 30th November 2015, 2:57 am
If you unplug temp sensor it runs in fault mode.
You best first off doing a fault code check just to see if throws up something useful.
You then could remove temp sensor & test it in some hot water with a thermometer & multimeter, want check harness/connector feed voltage contact condition etc. You could bridge the terminals on harness with 2000ohm resistor which would give ecu value of below 20degC so fans should be off & should start ok in sensible ambient climate. New sensor not expensive & can be had from £6 to £12 or grab some from junk yard as they used in loads of nissans.
10Starting problems  Empty Re: Starting problems on 1st December 2015, 8:44 pm
Rscozzy
Ecu temp sensor changed now starts when hot and fans working as should yeh even idles better
11Starting problems  Empty Re: Starting problems on 1st December 2015, 9:29 pm
Happy days mate ... glad its sorted ... Wink
12Starting problems  Empty Re: Starting problems on 1st December 2015, 9:32 pm
Great news, always good when it's an easy fix
13Starting problems  Empty Re: Starting problems on 1st December 2015, 10:23 pm
Well diagnosed MrB. Rep point given.
14Starting problems  Empty Re: Starting problems on 2nd December 2015, 2:11 am
Starting problems  WPFflags glad see R on the mend & an easy fix .
15Starting problems  Empty Re: Starting problems on 2nd December 2015, 12:00 pm
@Stu wrote:Well diagnosed MrB. Rep point given.
I feel sorry for Nomad I want to give him a rep point as Mr B is running away with it now yoursofunny
Spend the money, find a honey
Oh I wish that for the peace!
