Gtir Motorsport club » Tech room » Help and Advice » Sandwich plates
Sandwich plates
1Sandwich plates Empty Sandwich plates on 30th November 2015, 5:05 pm
Sandwich plates 997AADA5-6C89-4F9E-AD2A-98C99DB3EC71_zpsuivgzyr3
Right then, I have my mocal oil cooler, and just received the spa gauges, I didn't realise the spa gauge comes with a sandwich plate with the oil temp/oil pressure sensors in it. My question is can you use two sandwich plates at one time? I don't have the car atm to look at it all. I'm not sure if they will fit if you see what I mean, if not what can I do? Cheers for any help
2Sandwich plates Empty Re: Sandwich plates on 30th November 2015, 5:14 pm
Or do I remove the sensors from the sandwich plate and put them elsewhere?
3Sandwich plates Empty Re: Sandwich plates on 30th November 2015, 5:14 pm
Why would you want to run to sandwich plates i dont think its possible as one for room using a micra filter and two i dont think you can get a centre nut long enough ....
4Sandwich plates Empty Re: Sandwich plates on 30th November 2015, 5:18 pm
remove them & mount in suitable good points, pressure quite easy but temp really need nose of sensor in flow of oil or reading will be off . spa gauges don't come with sandwich plates, previous install had used one & bundled it together .
5Sandwich plates Empty Re: Sandwich plates on 30th November 2015, 5:28 pm
Ahhh I see, I didn't want to use two plates at all, that's why I asked, thought it seemed a little rough! So where would be a good place to put the temp sensor?
6Sandwich plates Empty Re: Sandwich plates on 30th November 2015, 5:42 pm
Some good pointers in this thread >
https://www.gtir-motorsport-club.com/t2080-how-to-replace-the-centre-gauges-with-new-52mm-items
but not the sump plug adaptors as read low & potential engine killer .
7Sandwich plates Empty Re: Sandwich plates on 30th November 2015, 5:52 pm
Cheers for that
