Gtir Motorsport club » Tech room » Help and Advice » High revs
High revs
1High revs Empty High revs on 21st December 2015, 10:18 pm
Rscozzy
Start car from cold revs stay st 2000 revs when it warms up it drops to just under 1000rpm then back up to 1500 revs stays there sometimes goes back to 1000revs changed temp sensor ,thermostat ,coolant sensor,check all pipes for leaks and dump valve new inlet gasket any ideas got apexi boost controller and apexi safc
2High revs Empty Re: High revs on 21st December 2015, 10:35 pm
Have you checked the tps ?
3High revs Empty Re: High revs on 21st December 2015, 10:37 pm
Rscozzy
How do I check it unluged it it revs up plug it back in revs go back down
4High revs Empty Re: High revs on 21st December 2015, 10:54 pm
Idle control valve under the plenum?
5High revs Empty Re: High revs on 21st December 2015, 10:57 pm
6High revs Empty Re: High revs on 22nd December 2015, 1:23 am
Ajay.
Check tps with multimeter in below link been a while since done mine but worth checking
http://www.plmsdevelopments.com/sr_setup_tips.shtml
7High revs Empty Re: High revs on 22nd December 2015, 1:40 am
Don't pierce the wires if you have a safc I will tell tomorrow but  your sensor check should let you do it
8High revs Empty Re: High revs on 22nd December 2015, 7:27 am
Rscozzy
Ok cheers Johnny
