Gtir Motorsport club » Tech room » Help and Advice » Water jacket gunk?
Water jacket gunk?
1Water jacket gunk? Empty Water jacket gunk? on 8th January 2016, 6:47 pm
Evenin,
I stripped the engine down this afternoon, when I removed the head I discovered one of the water jackets is completely blocked on cylinder 4
Water jacket gunk? 1A44B72E-B50E-4BA8-9B25-5025BBBDA09F_zpstnbouspo
I dug the stuff out with a small screwdriver
Water jacket gunk? B7AB55AD-C79D-48C1-8DF5-E6FA2453C974_zpsv4n8789q
Any idea what's caused this?  Under the head gasket a blob of liquid gasket was wedged in another smaller water way, same sealant as used around this housing
Water jacket gunk? 0FB9BFBA-E521-411F-881C-12B10E136A72_zpsvq45xstc
Wondering if this what caused the problem on the blocked jacket?
Gaz
2Water jacket gunk? Empty Re: Water jacket gunk? on 8th January 2016, 7:27 pm
possibly, not a big fan of use of sealants as seen too many problems due to excessive sealant.
Seen similar on a 7mgte I had displeasure of working on & that had clogged couple water ways due to sealant fragment partially blocking then further debris builds up round restriction.
Some coolant chemicals or leak additives can make interesting gunk & chemically react too .
You doing a full strip & clean ?
3Water jacket gunk? Empty Re: Water jacket gunk? on 8th January 2016, 7:43 pm
Of course Mr B full clean to match the car Laughing
Noticed one of the other liquid sealant joints had excess on from Nissan too! Hopefully not done any damage!
