Gtir Motorsport club » Tech room » Help and Advice » Removing valves
Removing valves
1Removing valves Empty Removing valves on 12th January 2016, 8:03 pm
Hi,
What tool do you guys use to remove the valves? I've got the tool below, had it years:
http://www.ebay.co.uk/ulk/itm/361431646692
But I'm liking this type:
http://www.ebay.co.uk/ulk/itm/191760340050
I'm thinking of making the above, got all the materials in garage.
Gaz
2Removing valves Empty Re: Removing valves on 12th January 2016, 9:29 pm
Animaldaz
If the head is off then the one you already have is perfect
3Removing valves Empty Re: Removing valves on 12th January 2016, 9:52 pm
Yeah heads off mate, cool will use that.
4Removing valves Empty Re: Removing valves on 13th January 2016, 9:45 am
grim_d
grim_d
Gaz
When are you making another pipe beader for me to purchase? Laughing
5Removing valves Empty Re: Removing valves on 13th January 2016, 11:20 am
hagger
i would recommend the bar style one as its a million times easier to use when you put it all back together.The bar goes under your arm and so you have both hands free.I made one from a standard valve spring compressor and it was worth the effort for sure.
