Gtir Motorsport club » Tech room » Help and Advice » Front and rear stabilisers
1Front and rear stabilisers Empty Front and rear stabilisers on 18th January 2016, 8:27 pm
Does anyone know the size of the front and rear engine stabilisers?
2Front and rear stabilisers Empty Re: Front and rear stabilisers on 18th January 2016, 8:46 pm
Like the length stu?
3Front and rear stabilisers Empty Re: Front and rear stabilisers on 18th January 2016, 8:49 pm
Yes mate
4Front and rear stabilisers Empty Re: Front and rear stabilisers on 18th January 2016, 8:51 pm
From hole to hole I need. Where the bolts go through..
5Front and rear stabilisers Empty Re: Front and rear stabilisers on 19th January 2016, 3:08 pm
Anyone? Sad
They are 90mm and 100mm on ebay but not listed for the gtir so need to know if these are any good for mine..
Mine have seperated from the metal and are destroyed inside so need them asap.
Thanks.
6Front and rear stabilisers Empty Re: Front and rear stabilisers on 19th January 2016, 6:42 pm
The front and rear engine stabilisers?. I can't measure the rear but can check the front
7Front and rear stabilisers Empty Re: Front and rear stabilisers on 19th January 2016, 7:21 pm
@mc_hawkings24 wrote:The front and rear engine stabilisers?. I can't measure the rear but can check the front
I have just removed the front one and filled it with loctite to see if it repairs it. If not I can measure that one.
Thank you all the same tho mate Smile
8Front and rear stabilisers Empty Re: Front and rear stabilisers on 19th January 2016, 8:04 pm
I think I have a rear one somewhere stu. If I can find it and I'll measure it for you.
9Front and rear stabilisers Empty Re: Front and rear stabilisers on 19th January 2016, 8:12 pm
Thanks woody Smile
10Front and rear stabilisers Empty Re: Front and rear stabilisers on 19th January 2016, 11:00 pm
Just measured both of mine Stu and they are both 90mm.
11Front and rear stabilisers Empty Re: Front and rear stabilisers on 19th January 2016, 11:19 pm
@splmum wrote:Just measured both of mine Stu and they are both 90mm.
Thankyou very much :-)
12Front and rear stabilisers Empty Re: Front and rear stabilisers on 19th January 2016, 11:46 pm
I have heard of these being filled with sikaflex or the like.
If you have any of the rubber left just fill them up as the rubber will help to keep the collar in the correct position.
13Front and rear stabilisers Empty Re: Front and rear stabilisers on 19th January 2016, 11:56 pm
I filled some engine mounts a long time ago, worked pretty well to make the mount more solid.
14Front and rear stabilisers Empty Re: Front and rear stabilisers on 19th January 2016, 11:59 pm
@splmum wrote:I have heard of these being filled with sikaflex or the like.
I have been told this before. Will grab some for when I get the new ones thanks.
I'm just trying the loctite that I had to hand. Probably won't work but nothing ventured nothing gained.
