Gtir Motorsport club » Tech room » Help and Advice » Knock/DET sensor issues
1Knock/DET sensor issues Empty Knock/DET sensor issues on 28th January 2016, 9:33 pm
Hardy172cup
Hardy172cup
I've had a problem with the knock sensor in my car for some time now, every now and then it would limit the boost and retard the timing as if it has detected DET. I would simply turn the ignition off then start the car back up again and it would be back to normal for a while.
I've currently had a new genuine Nissan knock sensor fitted but now the car seems to be constantly limited to 0.5 bar of boost like its in some kind of limp mode.
Does anyone have any suggestions what could be causing this? I'm sure the sensor is detecting false knock for some reason because it's been doing it for so long I would of run into issues by now if the engine was knocking.
2Knock/DET sensor issues Empty Re: Knock/DET sensor issues on 28th January 2016, 9:49 pm
luke s
Have you done a ecu check for codes to see if there's something else not happy bud
3Knock/DET sensor issues Empty Re: Knock/DET sensor issues on 28th January 2016, 9:57 pm
Hardy172cup
Hardy172cup
It's not showing any codes, I'm not sure since it's had the new knock sensor fitted because I haven't checked. I haven't got the car at the moment, it's at a garage so I can't check but it never threw up the code for the knock sensor before
4Knock/DET sensor issues Empty Re: Knock/DET sensor issues on 29th January 2016, 9:30 pm
How did you manage to get it off mate
5Knock/DET sensor issues Empty Re: Knock/DET sensor issues on 29th January 2016, 9:36 pm
Hardy172cup
Hardy172cup
@Bones wrote:How did you manage to get it off mate
I've had my gearbox done so got em to swap it over wile the engine was out. I'd of never got it off otherwise haha
6Knock/DET sensor issues Empty Re: Knock/DET sensor issues on 29th January 2016, 10:38 pm
It's like a reunion bones n hardy Razz
7Knock/DET sensor issues Empty Re: Knock/DET sensor issues on 30th January 2016, 9:01 am
could actually be det to some extent or something else resonating & new sensor picks it up well.
could do with fuelling & ignition checked to be safe (what ecu, piggybacks you got !). All super simple things likes plugs, leads, dizzy cap, sensor connectors, fuel pressure & pump voltage want be checked too.
Also if got real old fuel in tank that could do with draining .
8Knock/DET sensor issues Empty Re: Knock/DET sensor issues on 30th January 2016, 9:53 am
Hardy172cup
Hardy172cup
@Mr B wrote:could actually be det to some extent or something else resonating & new sensor picks it up well.
Cheers for that mate.
I don't think there's any major issue with feeling because I have a wide band but I'm not tuner so not sure exactly what numbers I should be seeing but it seems fine at WOT. Pump voltage and fuel pressure is something I've never checked. It's had new leads, plugs and distributor so shouldn't be a problem there. Never thought about draining the tank but I'm guessing it will be a ball ache lol
I've got a feeling this is going to cause me a real problem!
9Knock/DET sensor issues Empty Re: Knock/DET sensor issues on 30th January 2016, 9:54 am
Hardy172cup
Hardy172cup
Voltage to pump and fuel pressure sounds a good place to start I suppose
10Knock/DET sensor issues Empty Re: Knock/DET sensor issues on 30th January 2016, 9:55 am
Hardy172cup
Hardy172cup
I had thought about the possibility of something metallic touching the block making the sensor pick up false knock but can't think of anything that could be doing that
11Knock/DET sensor issues Empty Re: Knock/DET sensor issues on 30th January 2016, 6:59 pm
What exhaust have you got bill.... ????
12Knock/DET sensor issues Empty Re: Knock/DET sensor issues on 30th January 2016, 7:16 pm
Hardy172cup
Hardy172cup
I'm not even sure, think it's got a mongoose tip, standard downpipe but not sure what the centre section is. Stock elbow too
