Gtir Motorsport club » Tech room » Help and Advice » Help fitting hks afr
1Help fitting hks afr Empty Help fitting hks afr on 23rd February 2016, 1:14 pm
Hi guys.
I'm after a little guidance.
I'm fitting an hks afr.
Pin 36 i can use for the live?
Pin 39 i can use for ground?
It tells me Conect the yellow afr wire to the wire going to the ecu.
And Conect the white afr wire to the wire going from the ecu.
Pin 16 is the afr wire.
Is that in or out of the ecu?
Also if it is in, which pin is the afr out?
Or if it is out, which pin is the afr in?
Pin #
Name
Function
Signal Type
2
Tachometer Signal
Engine Speed Sensor Signal
Speed
4
Main Relay (Electronic Concentrated Control System)
12V Switched
Power
6
Power Ground (Electronic Concentrated Control System)
Chassis Ground
Ground
13
Chassis Ground
Ground
16
Mass Air Flow Sensor
Mass Air Flow Sensor Signal
Analog
17
Mass Air Flow Sensor Ground
Chassis Ground
Ground
18
Engine Coolant Temperature Sensor
Engine Coolant Temperature Sensor Signal
Analog
19
O2 Sensor Signal
Oxygen Sensor Signal
Analog
20
Throttle Position Sensor
Throttle Position Sensor Signal
Analog
21
Sensor Ground
Chassis Ground
Ground
26
Air Temperature Sensor
Air Temperature Sensor Signal
Analog
27
Knock Sensor
Knock Sensor Signal
Knock, Audio
29
Sensor Ground
Chassis Ground
Ground
32
Vehicle Speed Sensor
Vehicle Speed Sensor Signal
Speed
36
Ignition Switch
12V Switched
Power
39
Chassis Ground
Ground
46
Power Supply (Aux)
12V Permanent
Power
47
Power Supply (Engine Control Module)
12 Switched
Power
48
Chassis Ground
Ground
101
Injector # 1
Speed
103
Injector # 3
Speed
107
Chassis Ground
Ground
108
Chassis Ground
Ground
109
Power Supply (Aux)
12V Permanent
Power
110
Injector # 2
Speed
112
Injector # 4
Speed
116
Chassis Ground
Ground
2Help fitting hks afr Empty Re: Help fitting hks afr on 23rd February 2016, 1:16 pm
Also when I cut the afr signal wire and put the hks afr in its place, will the ecu then throw up a fault code because it's no longer getting a signal.
Or do I just splice the ecu wires so the ecu still gets a signal?
3Help fitting hks afr Empty Re: Help fitting hks afr on 23rd February 2016, 1:42 pm
Okay. I have figured it out I think.
Can someone just confirm this please.
(ECU MAF signal wire) Cut the Orange wire in half this is the MAF signal wire that will be running through the HKS AFR.
Yellow wire to Orange wire connect to ECU.
White wire to Orange wire connect to MAF.
4Help fitting hks afr Empty Re: Help fitting hks afr on 23rd February 2016, 1:43 pm
Cut pin 16 wire so you now got 2 ends
The end that goes to ecu has the yellow wire connected to it
The other end that feeds back to Maf has the white wire connected to it
Ecu still gets a signal (just a trimmed one via afr unit) so no fault if all wired & working correct
EDIT
you got it stu ...
Last edited by Mr B on 23rd February 2016, 1:45 pm; edited 1 time in total (Reason for editing : stu worked it out)
5Help fitting hks afr Empty Re: Help fitting hks afr on 23rd February 2016, 2:20 pm
Thanks MrB Smile
6Help fitting hks afr Empty Re: Help fitting hks afr on 23rd February 2016, 2:32 pm
which one you got stu, is it the single adjustment dial one with 4 wires !?
7Help fitting hks afr Empty Re: Help fitting hks afr on 23rd February 2016, 4:14 pm
Yes mate. Just the basic one.
The car had one installed when I first bought the car in 2009.
Ot no longer there and I just want to raise the afr slightly so have purchased one Smile
