Gtir Motorsport club » Tech room » Help and Advice » brake discs
brake discs
1brake discs  Empty brake discs on 11th April 2016, 4:30 pm
Can someone confirm these brake discs will work with the mitsubishi brake conversion?
http://pages.ebay.com/link/?nav=item.view&id=191411159196&alt=web
I know people use the clio 172 280mm discs?
Are these the same?
I have bought the fto twin pot (130mm) calipers. Which are the same as the evo 3 calipers.
Just looking for a cheaper alternative pair of discs Smile
2brake discs  Empty Re: brake discs on 11th April 2016, 5:21 pm
Expect so looking at fitment range in listing.
don't state centre bore or pcd but 99.9% it  right
Couple uk option only 50p more (although expect you will pay more than stated on you link item as when go checkout conversions are never exaclty same plus I think PayPal have a base conversion fee of like 20p or something )
http://www.ebay.co.uk/itm/RENAULT-Front-280mm-Diameter-Vented-Brake-Disc-By-Eicher-Premium-/221966029508?fits=Model%3AClio|Cars+Type%3A2.0+16V+Sport&hash=item33ae34d2c4:g:2yUAAOSwv-NWV4GU
http://www.ebay.co.uk/itm/One-Pair-Of-Quality-280mm-Front-Vented-4-Hole-Brake-Discs-/261582474948?fits=Car+Make%3ARenault&hash=item3ce787cec4:g:MeYAAOSwxH1UBiPx
disc spec is >
Type: Vented
Diameter (mm): 280
Thickness (mm): 24
Height (mm): 44
Centre (mm): 61
Mountings: 4 (PCD-100)
3brake discs  Empty Re: brake discs on 11th April 2016, 5:55 pm
Thanks Mrb Smile
4brake discs  Empty Re: brake discs on 11th April 2016, 7:19 pm
http://m.ebay.co.uk/itm/141771828422?_trksid=p2060353.m2749.l2649&_mwBanner=1
These are 5mm but i have them on mine and have had no problems. Stud holes are the same size as the studs so just file the centre bore out and a very miniscule file of the outside corner edge to match the internal edge of the disc. You'll see when you look at the disc as theres a slight internal chamfer
Edit: said's 124.99 but they are 24.99, they must have made a mistake on the listing.
5brake discs  Empty Re: brake discs on 11th April 2016, 7:33 pm
Thanks. I didnt want to spend that much tho lol
I have found these.
http://pages.ebay.com/link/?nav=item.view&id=281795267506&alt=web
Look like theres enough metal to have them milled to the size of the hubs..
6brake discs  Empty Re: brake discs on 11th April 2016, 7:37 pm
they'll work if turn them down to fit inside disc hat but also will need centre bore turned out to 60.1
7brake discs  Empty Re: brake discs on 11th April 2016, 7:40 pm
@Mr B wrote:^
Thanks mate Smile
I will measure the inside of the disc when they arrive and have them milled and bored to size Smile
I have asked the seller the external size of the spacer so i know theres enough metal to get rid of without affecting the stud holes.
8brake discs  Empty Re: brake discs on 11th April 2016, 8:14 pm
Oooh those are cheap. I'd say 40quid to turn them down at a machine shop.
Those were also 25quid not 124.99 you would just have to message them but don't matter now lol
9brake discs  Empty Re: brake discs on 11th April 2016, 8:21 pm
I will ask a favour. I worked at a place for 15 years what has a tool shop that makes pressing tools etc. So will ask my mate to get one of the lads to put them on the lathe and shave them to the right size for me. Will just be an extra drink at christmas that i have to buy Laughing
10brake discs  Empty Re: brake discs on 11th April 2016, 8:57 pm
As they got standard holes they will be fine to turn down, it only the multi fit type ones with slotted holes that the issue.
Favors are good :-)
11brake discs  Empty Re: brake discs on 11th April 2016, 10:23 pm
Okay cool. I ill buy them and get them sorted then. Mot is up soon so would loke to have them on for that Smile
Also have a buyer lined up for my standard callipers...
