Gtir Motorsport club » Tech room » Help and Advice » HELP!!! Oil on top of all the Pistons and blue smoke after engine rebuild!!!
Spark plug spike
Spark plug spike
Any ideas where to start looking, happened as soon as I started driving off only got to the end of the street and smoke was everywhere so turned round and parked back up.
Took plugs out and there was oil on the top of all the Pistons, compression tested it and got
160
170
169
162
Sprayed carb cleaner down the bores, cranked over for 30 seconds until they were dry then did another compression test and got
162
172
171
166
Put it all back together and took it for a 1 mile drive down the dual carriageway still smoked and once again had oil on the Pistons censored
Hope it's not a strip down again suicide
Check and see if valve stem seals are pushed all the way down or even fitted. How much oil pressure is it showing
Spark plug spike
Spark plug spike
Cheers, the oil pressure was about 5 on cold start up, 2 on hot idle rising to 4 with some revs.
How do I check the valve stem seals?
Spark plug spike
Spark plug spike
Pulled the exhaust manifold forward and all the ports were bone dry, took some photos of the valves the best i could with the USB boroscope camera sorry for the quality.
Any ideas where to look next????
HELP!!! Oil on top of all the Pistons and blue smoke after engine rebuild!!! Win_2010
HELP!!! Oil on top of all the Pistons and blue smoke after engine rebuild!!! Win_2012
HELP!!! Oil on top of all the Pistons and blue smoke after engine rebuild!!! Win_2011
HELP!!! Oil on top of all the Pistons and blue smoke after engine rebuild!!! Win_2013
HELP!!! Oil on top of all the Pistons and blue smoke after engine rebuild!!! Win_2014
HELP!!! Oil on top of all the Pistons and blue smoke after engine rebuild!!! Win_2016
HELP!!! Oil on top of all the Pistons and blue smoke after engine rebuild!!! Win_2017
HELP!!! Oil on top of all the Pistons and blue smoke after engine rebuild!!! Win_2015
Compression is good which rules out rings,
That only leaves,
Intake valve seals (unlikely),
Head Gasket failure,
Blown turbo seals,
I cant think of any other leak paths,
Very Happy
It don't rule out assembly or other issue with oil control rings .
What you done to engine during rebuild ?
was it bored honed and to what clearance?
new rings?
valve assembly checked or new valves, guides, seats cut, new seals fitted ?
being oil in all 4 cylinders it hopeful it more likely coming from turbo or perhaps a breather system issue !
Have a look at inlet manifold for oil & track back & see if intercooler got oil in it .
Valve seals are easily fitted badly but to do all 4 cylinders badly seem unlikely but is possible, also some after market seals are poor fitting and troublesome .
Not a good start but hopefully will not be major build issue :-S
GTIR James
From them pictures id say the valve stems are dry & not leaking. My rebuilt engine was the same. Id also be looking at cylinder to piston wall clearance & ring gaps.
Any problems getting the piston into the cylinder as the oil control rings are extreamly delicate
Have you blocked the breathers on rocker cover?
Spark plug spike
Spark plug spike
After chatting with Bob on the phone he suggested checking the turbo before stripping anything off the engine and guess what he was right you the man
Even though there was minimal movement when I checked before refitting it, it had quite a bit of play when I removed it???
Had a spare rebuilt CHRA so swapped all the parts over and refitted it and hey presto smoke screen gone.
Still got a little bit of smoke at idle and the oil is still on the Pistons, but probably needs a good couple of hundred miles running in first then see if it stops?
Going to book an MOT tomorrow and fingers crossed it passes then I can get run in.
We mentioned that in replies above, generally easy see oil residue on inlet pipes even if turbo bearings feel OK and one of first checks to do when burning oil, clean out you intercooler too as that probably full of oil as must of been throwing out fair bit of oil if could see wet oily postons. Was favourable chance seems all 4 cylinders getting oily and way simpler than engine build errors so happy days hopefully...
Spark plug spike
Spark plug spike
@Mr B wrote:We mentioned that in replies above, generally easy see oil residue on inlet pipes even if turbo bearings feel OK and one of first checks to do when burning oil, clean out you intercooler too as that probably full of oil as must of been throwing out fair bit of oil if could see wet oily postons. Was favourable chance seems all 4 cylinders getting oily and way simpler than engine build errors so happy days hopefully...
Sorry B, didn't see the posts until after Bob had called me back but thanks for all the advice it's really appreciated thumbsup
Passed the MOT on retest due to the horn not working and excess smoke, changed the horn and took it for another 10 mile blast and the smoke was minimal so it passed. Now taxed and had a 40 mile drive and all seems good now (fingers crossed)
^ main thing is was simple resolve and engine build ok . Nothing worse than issues on rebuilt engine but nice when don't turn out be super serious problem :-D have fun running it in ...
Spark plug spike
Spark plug spike
Wasn't happy with the smoking so had my spare turbo rebuilt
HELP!!! Oil on top of all the Pistons and blue smoke after engine rebuild!!! Image13
HELP!!! Oil on top of all the Pistons and blue smoke after engine rebuild!!! Image10
HELP!!! Oil on top of all the Pistons and blue smoke after engine rebuild!!! Image11
HELP!!! Oil on top of all the Pistons and blue smoke after engine rebuild!!! Image12
All good now and no smoke, time to carry on running her in now Very Happy
Good news mate Smile
How much was the rebuild on turbo and is it a standard t28?
Great news
Spark plug spike
Spark plug spike
Cheers fellas, did 250 miles on mineral oil and changed the oil and filter topped back up with fresh mineral for the next 250 miles then will change to Fuchs Titan Pro 10-50.
Here's the invoice standard turbo with 360 bearing upgrade.
HELP!!! Oil on top of all the Pistons and blue smoke after engine rebuild!!! Image14
I got my shaft balanced by them, very quick turn around, defo use them again in the future.
I think thats a very reasonable price thumbsup
Yeah they are great had a core off them a while back was spot on.
Spend the money, find a honey
Oh I wish that for the peace!
Very interesting and informative read for a Sunday morning cheers
