Gtir Motorsport club » Tech room » Help and Advice » Starter issue
Starter issue
1Starter issue Empty Starter issue on 24th June 2016, 8:24 pm
sooni
Hi all
I could hear the starter still turning/dragging with the fly wheel 4-5 seconds after the car is started but now is not even turning/making any sound or effort to start the car,I've checked the battery is 12.8v before start and 13.7v when engine is on,the car starts easily when bump started which makes me think that could be the starter goosed
I haven't had the car long 2 weeks so I can't say for how long is been like that, is there a easy way to check if it's the starter and what is the best way to take it off?Cheers
2Starter issue Empty Re: Starter issue on 24th June 2016, 9:15 pm
I would say solenoid bad on starter .
Do check wiring on starter as trigger wire is known come off in some instances but with pre full failure issue you had I would say mechanical wear in solenoid throw mechanism.
You can try tapping solenoid on starter with solid wood pole or hammer shaft or similar and see if gets it working. New or recon starter likely
Links below to help:
starter fault >
https://www.gtir-motorsport-club.com/t4967p25-none-starter
New strarter motor >
https://www.gtir-motorsport-club.com/t4979-new-alternator-starter-motor
3Starter issue Empty Re: Starter issue on 24th June 2016, 9:20 pm
Pray and keep fingers crossed that the y bracket isn't still on the engine lol you'll have fun taking the starter off if it's still connected
4Starter issue Empty Re: Starter issue on 24th June 2016, 9:47 pm
sooni
When I turn the key to start the car I can't hear the starter clicking?, I think the y bracket is out tom,but think the inner bolt will be a pain though
5Starter issue Empty Re: Starter issue on 25th June 2016, 6:24 am
Is that Lukes old car?? If yes then there is no bracket
6Starter issue Empty Re: Starter issue on 25th June 2016, 6:33 am
Sounds like the starter to me. As B said, give it a good whacking and see if that gets it working.
7Starter issue Empty Re: Starter issue on 25th June 2016, 8:40 am
sooni
@Gostek wrote:Is that Lukes old car?? If yes then there is no bracket
hi,Yes that's luke's old car.
Michal I may contact you about the cat mate, I have some questions about the built and the clutch etc,if that's ok.cheers Dimitar
8Starter issue Empty Re: Starter issue on 25th June 2016, 8:44 am
sooni
@gtir_woody wrote:Sounds like the starter to me. As B said, give it a good whacking and see if that gets it working.
Hi woody
Yes I gave it a good wack and it's starting now,need to think about getting it changed or repaired,cheers
9Starter issue Empty Re: Starter issue on 25th June 2016, 9:11 am
^ yep, sticky/worn solenoid & throw mechanism, any decent local elec shop should be able sort that out on your unit or offer exchange, If hunt around you may find solenoid parts cheap enough do repair yourself but do inspect/look at starter prior to deciding on this .
10Starter issue Empty Re: Starter issue on 25th June 2016, 9:14 am
sooni
Thanks for your help guys appreciated.
