Gtir Motorsport club » Tech room » Help and Advice » Starting woes
Starting woes
1Starting woes Empty Starting woes on 3rd July 2016, 9:07 pm
I'm assuming it's starter motor related but got the engine fully back in this evening, fluids etc went to crank it and absolutely nothing, not a click suicide
Last Saturday before I took the engine out it worked, thinking a cable had popped off it I stuck the endoscope down there and both are on.
I've ruled out immobiliser as fuel pump works and not touched anything to do with that.
The thing I'm really cheesed about is for the second time in 3 weeks I've put the Y bracket back on censored so now getting to the starter is going to be a mare!!
Is there anything else I can check first? Am I right in thinking a wire from battery goes to ignition then to starter nothing inbetween?
Gaz
2Starting woes Empty Re: Starting woes on 3rd July 2016, 9:26 pm
Gtirchris
The big main live goes straight from battery to starter, and yep, you're correct there is the wire that goes from the ignition switch to the starter solenoid, it could just be a bad connection mate, have you checked the main earth between battery and thermostat housing?
3Starting woes Empty Re: Starting woes on 3rd July 2016, 9:49 pm
Yeah last thing I put on, will have another look at the starter in a few days once I get some R enthusiasm back Laughing
4Starting woes Empty Re: Starting woes on 4th July 2016, 10:21 pm
May have found the non starting issue
Starting woes 15FE13F4-4DF5-445A-B66E-3D9A2CDA2BFF_zpsfo4rqxyc
Starting woes 7A747E35-35C6-4055-8E8D-4266AE6B9E8F_zpsgwmopcit
Need to make a tool to hook round it and pull it on can't get my spade like hand down there, looks as though I've snagged the loom and pulled it free nearly, maybe just not making a connection with the grease stuff to stop water ingress that's over the connectors.
I'm hoping it's just that anyway!
5Starting woes Empty Re: Starting woes on 5th July 2016, 2:15 am
Good chance it is, have had that cable corroded and broken within sheath near spade before too .
6Starting woes Empty Re: Starting woes on 6th July 2016, 11:05 am
Bit bored in work watching the apprentice fook the galv job! Got thinking of how I can get the loose plug back on the starter without dropping the engine or stripping things down, so decided to make myself a reach around tool Laughing
Starting woes EA411E51-1C79-4D4F-B17F-24DDC597387E_zpsnwjxnavb
Starting woes 16D217D6-EDFD-4E33-98BE-9CFB6850137C_zpskbtc3ddt
Starting woes A803D741-2333-474D-98B2-DD3674542203_zpsnl6jn1j8
Should be able to pull the loose plug on easy Laughing even has a handy handle.  Already started thinking of modifying it, if I thread the end I can make multiple attachments thumbsup
Think this is going to be my favourite tool now Laughing
7Starting woes Empty Re: Starting woes on 6th July 2016, 11:15 am
Thats ace! Fingers crossed it works.
Fuck knows why you put that Y bracket back on tho?
I have a spare one if anyone wants one? Gotta be quite rare these days lol
8Starting woes Empty Re: Starting woes on 6th July 2016, 11:45 am
Stu I really don't know, thought it looked good Laughing next time the lumps out the brackets going back in the loft Laughing
9Starting woes Empty Re: Starting woes on 6th July 2016, 6:40 pm
Well the reach around didn't work Laughing 20mm conduit too big to get through the tight gap! So made this
Starting woes 79650ADF-C659-4B5B-B2A5-57B985B3F51F_zps6whldmgp
Pleased to say it worked and the car now cranks over!! Result Very Happy
10Starting woes Empty Re: Starting woes on 6th July 2016, 7:54 pm
You and your custom tools lol. Wales 1 Nissan 0 . Keep it up Wales ...
