Gtir Motorsport club » Tech room » suspension set up & info » CV Joint Grease
CV Joint Grease
1CV Joint Grease Empty CV Joint Grease on 22nd November 2017, 10:48 pm
Pulsartim
Pulsartim
Hi guys can anyone tell me what grease is recommeded for the drive shaft CV joints front and rear, Nissan has 3 differnt part numbers, one for the front and rear inner joints, one for the front outer joints and another one for the rear outer joints.........I'm stuggling to find a OEM part number spec sheet that converts to a none genuine grease. I know the inners and outer run different grease from when I stripped them apart.
2CV Joint Grease Empty Re: CV Joint Grease on 22nd November 2017, 10:55 pm
I would of thought any moly lithium grease would be more than sufficient. ..
