Gtir Motorsport club » Tech room » Help and Advice » ecu fault code check
1ecu fault code check Empty ecu fault code check on 9th March 2012, 5:42 pm
Switch ignition on but don't start the engine. In the grey plug under the fuse box, connect the two right pins (chk and ign) with a paper clip for example, for 3 seconds (the engine check light will turn off while you are shorting them out). The engine check light will flash a series which will indicate a code -
Long long long long long (pause) Short short short short short - indicates 55 which is no fault.
If it flashes 3 long and 4 short for example it's the Det sensor.
To clear the ECU codes, short the wires out again while it is flashing the code.
ecu fault code check Ecu_code_plug
ecu fault code check Zi1
ecu fault code check Fault20check
