Gtir Motorsport club » Tech room » Help and Advice » Problems on my GTIR
Problems on my GTIR
1Problems on my GTIR Empty Problems on my GTIR 29th June 2020, 11:19 am
Japi-
Hello guys,
Now I had a small problem in my GTI-R.
The instrument panel(cluster) fuel gauge stopped working. The needle has gone to the far left.
Could the problem be the instrument cluster or the fuel sensor?
Best regards, Jani
2Problems on my GTIR Empty Re: Problems on my GTIR 30th June 2020, 2:38 am
Id start with the fuel sensor, you can test it and find out. EL-120 and EL-121 in the workshop manual.
3Problems on my GTIR Empty Re: Problems on my GTIR 30th June 2020, 5:10 am
Japi-
@gtir_woody wrote:Id start with the fuel sensor, you can test it and find out. EL-120 and EL-121 in the workshop manual.
Ok, thanks. I check these.
BR, Jani
4Problems on my GTIR Empty Re: Problems on my GTIR 30th June 2020, 11:53 am
I would do same Woody suggests, generally it easiest place start if no other issues on gauge cluster making it look like the cluster more likely at faulty .
You can spoof values to the gauge with a resistor/jumping the sender wires .
Here's a link to PDF of the manual pages
https://drive.google.com/file/d/1hWz3QBmwD3auHw4AxMZddyVgY-6nWlSn/view?usp=sharing
here's a thread link on gauge sender readings
https://www.gtir-motorsport-club.com/t8220-gtir-fuel-sender-ohms-readings
gtir_woody likes this post
