Gtir Motorsport club » General Discusion » Gtir related Discussion » OEM Fuel pump flow rate
1OEM Fuel pump flow rate Empty OEM Fuel pump flow rate 5th February 2021, 7:46 am
Armaki
Hi Guys, Newbie here....
I am working on repairing a Gtir, stored for years with a seized OEM pump. As the original is no available anymore, i am looking for something as close as possible to the OEM specs and size, since the car is bone stock and the owner wants to keep it that way.
I know that Walbro 225 is the go to solution, but i was looking for something from the Nissan range first. Any suggestions?
What is the flow rate of the stock pump?
Thanks!
2OEM Fuel pump flow rate Empty Re: OEM Fuel pump flow rate 5th February 2021, 8:16 pm
Welcome to the club Try bob on here he might have one 01702864914
He is always super busy so be patient
3OEM Fuel pump flow rate Empty Re: OEM Fuel pump flow rate 5th February 2021, 8:19 pm
Armaki
Thanks, is this a part number or a German mobile phone number?
4OEM Fuel pump flow rate Empty Re: OEM Fuel pump flow rate 5th February 2021, 8:24 pm
No it’s a landline number
5OEM Fuel pump flow rate Empty Re: OEM Fuel pump flow rate 5th February 2021, 9:54 pm
original can still be found new from online part suppliers .
part number 1704054C10
if you put a request in parts wanted section someone will have one for sure as most swapped out oem pump .
6OEM Fuel pump flow rate Empty Re: OEM Fuel pump flow rate 6th February 2021, 8:52 am
Armaki
Yes, i found that, but the prices are a bit crazy.
I will try the parts request section, thanks.
7OEM Fuel pump flow rate Empty Re: OEM Fuel pump flow rate 7th February 2021, 4:46 pm
Cheers Johnny thumbsup
Yes we have good stock pumps in gwo (well 3 left now)
Best off dropping me a text to 07723 361027 and will sort it out if still needed
8OEM Fuel pump flow rate Empty Re: OEM Fuel pump flow rate 7th February 2021, 5:48 pm
Armaki
Whatsapp on its way.
