Gtir Motorsport club » Tech room » Help and Advice » Alternator Belt help!
1Alternator Belt help!  Empty Alternator Belt help! on 20th February 2013, 2:37 pm
Rot box revival!
Howdy
Got a bit of a dilemma wif the alternator belt. Does anybody know what length the belt should be when the air con pump is removed?
Cheers in advance troops
Davy
2Alternator Belt help!  Empty Re: Alternator Belt help! on 20th February 2013, 3:34 pm
Its a 4 rib length its either a 330 or 335 cant remember what one i used mate
3Alternator Belt help!  Empty Re: Alternator Belt help! on 20th February 2013, 3:49 pm
Rot box revival!
Cheers man
I'm sure mine was a six rib, does it matter? My car had air con but I've decided not to keep it cos Scotland never gets that warm!
4Alternator Belt help!  Empty Re: Alternator Belt help! on 20th February 2013, 4:42 pm
just get a piece of string and wrap it round the pulleys where the belt will go, tie it off and theres your template for when you go to a motorfactors Very Happy
5Alternator Belt help!  Empty Re: Alternator Belt help! on 20th February 2013, 5:45 pm
Mines also a 4 rib but not sure what length?
6Alternator Belt help!  Empty Re: Alternator Belt help! on 20th February 2013, 5:59 pm
You can han have either 6 rib is the oe part but when your not churning the ac pump then it abit over kill but it doesnt matter wether its 6 or 4
7Alternator Belt help!  Empty Re: Alternator Belt help! on 20th February 2013, 6:36 pm
Animaldaz
A gates 5pk838 fits well.
8Alternator Belt help!  Empty Re: Alternator Belt help! on 20th February 2013, 8:06 pm
Rot box revival!
Cheers lads
Much appreciated
9Alternator Belt help!  Empty Re: Alternator Belt help! on 4th July 2016, 8:34 am
I just brought a 4pk845 (which alot of people run) and its massively too big on mine, what length do other people run? I haven't bothered to measure it yet Laughing
10Alternator Belt help!  Empty Re: Alternator Belt help! on 4th July 2016, 9:02 am
Qbr 6838 quinton hazel drive belt
Qbr 4925
Alt and aux belts I run both quinton hazel part numbers
Ps 6 rib alt belt I just think it sits on pulley better and more so if pulley is uprated
11Alternator Belt help!  Empty Re: Alternator Belt help! on 4th July 2016, 9:04 am
@gtir_woody wrote:I just brought a 4pk845 (which alot of people run) and its massively too big on mine, what length do other people run? I haven't bothered to measure it yet Laughing
I find same on couple I done. 845 too big or at best tensioner at max
Other end of scale was 825 and that too tight really .
Those sizes used/mentioned as popular and easy find.
I ended up going with 6PK835 in end (skf belt)
Had tried dayco which matched 830 direct cross interchange but is actually 825.5  so tight .
6PK835 was easy get as used on daihtsu and Subaru, skf was less than 400baht .
I still use air-conditioning on road car, I'm soft lol ...
12Alternator Belt help!  Empty Re: Alternator Belt help! on 4th July 2016, 9:27 am
Thanks B I was thinking Id get an 830 but good point about it actually being smaller than listed, maybe ill go an 835 to be safe. Its weird that 845 was too big, guess we have a smaller alternator pulley.
13Alternator Belt help!  Empty Re: Alternator Belt help! on 4th July 2016, 10:11 am
An 830 that was 830 would be good, I asked for 6rib 830 belt from good brand, they had dayco on shelf so snatched there hand off, when tested it found same issue as 825 (it tight fit)
compared to 825 & found same & when checked dayco details found its effective length was 825.5 :-/
SKF VKMV-6PK830 was next best option when went back, nice belt and at 400Bt (14AUD) couldn't complain .
using length of rope & setting pulley at half adjustment is how got my idea on length .
I've done 2 pulsars with these belts as seem ideal fit, I would say anything from 830 to 838 would work, I like 6 ribbed as looks proper fit & lasts way better .
14Alternator Belt help!  Empty Re: Alternator Belt help! on 4th July 2016, 8:46 pm
Awesome thanks mate Smile rep
15Alternator Belt help!  Empty Re: Alternator Belt help! on 5th July 2016, 2:11 am
That meant to say SKF VKMV-6PK-835 .
16Alternator Belt help!  Empty Re: Alternator Belt help! on 5th July 2016, 7:44 am
Dropped by the local parts store on the way home, they only had a 830 so I thought fook it I'll give that a go, bastard is shorter than 830 as you said B Laughing ordered the above online Smile
17Alternator Belt help!  Empty Re: Alternator Belt help! on 5th July 2016, 11:02 am
Haha not just here then :-)
all common ones that parts matched 830 seemed that way when I looked into it deeper, 835 & 836 was next size which seemed easier source & lengths as stated plus being middle ground of 825<>845 was a safe bet that worked out perfect & cheap .
18Alternator Belt help!  Empty Re: Alternator Belt help! on 16th July 2016, 7:00 am
Fitted the 6PK-835 this arvo B, was a really good fit, sits abit over half way, gave ya a rep for the help Smile
19Alternator Belt help!  Empty Re: Alternator Belt help! on 16th July 2016, 9:26 am
Glad here it fitted sweet .
About best length option really but not most common in retailers but internet makes stuff so easy these days ...
20Alternator Belt help!  Empty Re: Alternator Belt help! on 16th July 2016, 9:35 am
Im glad im building a car in the age of the internet Laughing
